top53 53 Posted August 26, 2012 Ordered on Tuesday at 4:00 P.M. received it on Wednesday by 5:pm cut 30" X 16 foot sign by Thursday. You talk about getting the job done. I just wanted to express my appreciation to USCutter for a job well done. I would loved to have had another Graphtec but this will have to do for now, I will use it as a back up. Seems to work fine except it sure is loud. 1 Share this post Link to post Share on other sites
slice&dice 2,450 Posted August 26, 2012 You will probably also notice that it uses a stepper motor, which leaves 'ridgies' along the diagonal cuts. Share this post Link to post Share on other sites
top53 53 Posted August 26, 2012 Why does the heart look fine but the fonts look so bad. I am going check this out this afternoon, how big is your font. When I cut the test square it did not have them and it was at a diagonal. O well I completed this job without them and I will check it out this afternoon. Thanks for the heads up. Share this post Link to post Share on other sites
mb20music 760 Posted August 26, 2012 You will probably also notice that it uses a stepper motor, which leaves 'ridgies' along the diagonal cuts. There is definitely something wrong here, a properly functioning/setup cutter will not do this. 1 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 26, 2012 I used a cutter with a stepper motor before I got my Graphtec, and never had anything like this in any direction. It was not a USCutter model, but was still a Chinese cutter with a stepper motor. And I still have it.. That work would not go out my door to a customer. 1 Share this post Link to post Share on other sites
slice&dice 2,450 Posted August 26, 2012 There is definitely something wrong here, a properly functioning/setup cutter will not do this. What could I adjust? It just 'bumps' (chatters) along on the diag. and has been doing so since day one. Share this post Link to post Share on other sites
top53 53 Posted August 26, 2012 Hi, just got back. I ran a cut 12" font "W,X" and my SC Cutter does not do that. You may need to make some adjustment. See pic. 1 Share this post Link to post Share on other sites
speleopower 46 Posted August 27, 2012 Hi-My 34" SC machine does not do that at all. -Scott Share this post Link to post Share on other sites
Binford 53 Posted August 27, 2012 My SC 34' does not do that , maybe adjust your Gram pressure or your speed ... just a Idear Share this post Link to post Share on other sites
slice&dice 2,450 Posted August 27, 2012 Hmmmmmmmm, sorry for the thread hijack. According to you good folks posting here, these 'jaggies' are not a normal operating circumstance, so I decided to look into eliminating them. After reviewing some other threads here, I discovered that the belt that moves the carriage (blade-holder) head has a tensioner adjustment, accessible by removing the entire left hand (power plug/onoff) side cover. Added some slight tension, and my crazy wigglies are now gone. 2 Share this post Link to post Share on other sites
speleopower 46 Posted August 27, 2012 Excellent! I was planning on taking the side panel off of my SC and see what adjustments there might be. -Scott Share this post Link to post Share on other sites
top53 53 Posted August 28, 2012 Glad you got it fixed. Do you have much work that you will have to redo. Share this post Link to post Share on other sites
slice&dice 2,450 Posted August 28, 2012 Nah, as it happens, that picture I posted isn't even from my machine -- it's a photo that was copied from another thread by someone else, showing a REALLY REALLY drastic example of the jaggies. (Horrific, in fact) My own machine produced very minor & almost imperceptible ridges, so minor in fact that I couldn't get my camera to record an image to show what was happening. I could only see them with my reading glasses at close range, and for sure the signs that I was making don't look bad at all. Unless you are taking a very close look & inspecting the edges of individual letters you won't see jaggies, and nobody does that with signs meant to be viewed from 30-40 feet away. Anyway, now that I've corrected the tensioner, even those minor steps on the edges are gone. I just figured it was "normal" until the folks in this thread pointed out that I should be getting a totally clean cut. Which I now do obtain, so thanks everyone who offered their 2c. Share this post Link to post Share on other sites
GET Longboards 0 Posted August 29, 2012 About how many turns did you do on the tensioner screw? Share this post Link to post Share on other sites
liquidfusion 69 Posted August 29, 2012 Great info being conveyed here, Its appreciated... Bruce Share this post Link to post Share on other sites
slice&dice 2,450 Posted August 29, 2012 About how many turns did you do on the tensioner screw? One-1/2 rotations. Also, while I had the opportunity, I drilled a new hole for the set-stop screw on the rear rail that provides a limitation to the motion of the right-hand pinch roller as it slides over. (The factory-placed location of that set-stop was too far to the right, and allowed the roller to reach a spot that MISSED the grit rollers!!!!!) Share this post Link to post Share on other sites
GET Longboards 0 Posted August 29, 2012 One-1/2 rotations. Also, while I had the opportunity, I drilled a new hole for the set-stop screw on the rear rail that provides a limitation to the motion of the right-hand pinch roller as it slides over. (The factory-placed location of that set-stop was too far to the right, and allowed the roller to reach a spot that MISSED the grit rollers!!!!!) Awesome I will have to tighten that up and see if i can fix the slightly jagged edges im getting. I also noticed the pinch roller issue. I guess thats what you get when you buy a budget cutter. Share this post Link to post Share on other sites
speleopower 46 Posted August 30, 2012 I ended up tightening the belt a little on mine tonight. I didn't really not a difference other than it seems a little louder. Does anyone know what the tension should be on the belt? -Scott Share this post Link to post Share on other sites
GET Longboards 0 Posted August 30, 2012 I ended up tightening the belt a little on mine tonight. I didn't really not a difference other than it seems a little louder. Does anyone know what the tension should be on the belt? -Scott Were you having issues before? Share this post Link to post Share on other sites
speleopower 46 Posted August 30, 2012 Very slight issues with having small "hairs" attaching letters to the main part of the vinyl or what seem like blade offset issues but don't change regardless of what offset I set. It seems to be more of a problem with cutting fonts than cutting vector images I have created. And of course the smaller the font the more noticeable the problem is. The worst is when I try and cut lower case "a", "e" and "i". -Scott Share this post Link to post Share on other sites
GET Longboards 0 Posted August 30, 2012 Very slight issues with having small "hairs" attaching letters to the main part of the vinyl or what seem like blade offset issues but don't change regardless of what offset I set. It seems to be more of a problem with cutting fonts than cutting vector images I have created. And of course the smaller the font the more noticeable the problem is. The worst is when I try and cut lower case "a", "e" and "i". -Scott hmmm have you made sure the fonts are clean. I find sometimes that the fonts arent the greatest. What cutting and designing programs are you using? Share this post Link to post Share on other sites
speleopower 46 Posted August 31, 2012 I am using Signblazer for cutting and Inkscape/Signblazer for design. Yes I'm of the opinion it is the font causing me the most grief. Tonight I cut 6 sets of the following letters "ifgtae" using different speed and offset. One font will be nearly clan while another font has slight issues. The font I have tried cutting the most is Arial rounded MT. All of the "i" letters and "a" letters have minor issues and it doesn't matter what blade offset or speed I run at the issues are always at the same location on the font. When I zoom in real tight with Signblazer and look at the letters the font appears clean. I do not know how to edit a fonts nodes. -Scott Share this post Link to post Share on other sites
GET Longboards 0 Posted August 31, 2012 I am using Signblazer for cutting and Inkscape/Signblazer for design. Yes I'm of the opinion it is the font causing me the most grief. Tonight I cut 6 sets of the following letters "ifgtae" using different speed and offset. One font will be nearly clan while another font has slight issues. The font I have tried cutting the most is Arial rounded MT. All of the "i" letters and "a" letters have minor issues and it doesn't matter what blade offset or speed I run at the issues are always at the same location on the font. When I zoom in real tight with Signblazer and look at the letters the font appears clean. I do not know how to edit a fonts nodes. -Scott a couple of options you can select in cutter set up is like fastest path, normal, and best tracking. Also to edit the nodes click the button 6 to the left of the select button. Share this post Link to post Share on other sites
Binford 53 Posted September 2, 2012 Scott i get that to , with the smaller the Font .. on my SC... just like you ... but with Vector images always comes out wonderful... Your not alone buddy A-E-I its more noticeable with smaller the font but Big fonts come out real good .. Thanks slice&dice for the info brother Share this post Link to post Share on other sites
speleopower 46 Posted September 6, 2012 Yup the vector images I have drawn seem to turn out pretty much good not matter how small I try and cut them. It's the fonts that are cut cutting clean and yes the larger the font the less noticeable the tiny hairs are. Any ideas on how to "clean up" fonts? That is something I have no idea how to do. -Scott Share this post Link to post Share on other sites
