strycnine
Help understanding
What is the center that you are referring to that is missing? It all appears to be there to me.
I don't know much about Signcut itself, but maybe try a different file format? pdf, ai, svg, something like that? If you need it converted to any of those, let me know.
Here is just the logo, you will need to add the text back. It had a BUNCH of layers. How this helps you out
Thanks brother!
In Corel, ungroup your graphic then go to the VIEW drop down menu and click on Wireframe.
Now all you will see are outlines of the objects on your page...no fills.
These outlines are the cut lines for your cutter.
If your object has both line and fill, you will see this in wireframe view
and you can eliminate those extra cut lines.
If the extra layers are exactly on top of one another you won't see them until you delete one.
If you select one object, hit delete and the outline remains...you have hidden layers.
Delete until you get to only one.
If you remember that what you see in wireframe is EXACTLY where your cutter blade
is going you can correct many things before ruining good vinyl.
Sue2
