noladecals 0 Posted July 8, 2012 I've been using my Copam CP-2500 for about 6 months most of the time with a 45 degree angle blade. It cuts well but I'm starting to mess around with more detailed designs. I'm getting a lot of vinyl lift and I'm wondering if a different blade angle would make a difference. I've read that clean cut blades are really good. I see they have 30, 45 and 60 degree blades. Am I correct in assuming the smaller the degree blade, the better it will be for detailed designs? Share this post Link to post Share on other sites
mb20music 760 Posted July 8, 2012 60 Degree blades are best for cutting small letters and detailed designs Share this post Link to post Share on other sites
noladecals 0 Posted July 9, 2012 Ok thanks. I thought it was the other way around. Share this post Link to post Share on other sites
mb20music 760 Posted July 9, 2012 FROM USCUTTER WEBSITE Rationale for blades of different angles The primary rationale for blades of different angles is cutting depth. A lower angle (45 degree) is great for thin materials, while a steeper angle (60 degrees) has a more vertical cutting orientation that penetrates deeper. An increased amount of blade dragging through the material when cutting fine detail can cause, what they call, vinyl ears (parts lifted up). With minimal blade in the material, a 60 degree blade tends to cause fewer, if any, vinyl tears. Using a 60 degree blade on everyday cutting is a waste of a blade, technically speaking. Less of the blade's cutting area is used, and blade life is wasted. The more horizontal cutting orientation of the 45 degree blade accurately distributes the cutting task over a larger blade area, and thus last longer (and is cheaper). So use a 45 degree blade always, unless a 60 degree blade is needed for thick or more custom types of cutting, if 45 degrees blades are not available. 2 Share this post Link to post Share on other sites
