tservice
8.6 starter undo contour cut??
I have 8.6 and I have a saved file. I need to edit it. But I have to undo the contour cut outline. How do I undo that?
thanks
under effects I only have 2 options, 1. contour cut. 2. contour cut mark :/
sorry I didn't see it was starter.... Starter must not allow for this. post the file I will see if it will work with mine.....
that is perfect, thanks so much. idk why SAI did not include a undo for that.....
To make you have to upgrade usually... Was that something you created??? You may have to select the whole image open up your design central go to the tab all the way on the left and click the red "X"... I don't know if that will do it either..... It would seem if you can contour cut with Starter you should be able to undo it.....
I have never found a way to undo it. I always save before and after. I will contact support and see. thanks againfor your help.
