cutter_noise
Cable torn from cutter
I have a 7 year old CT-630 P-Cutt vinyl cutter that I use at home for overflow work. Recently tripped over the cable and tore it right out of the side of the machine, and now I can't determine which wires go where. The ribbon cable that goes from the circuit board has become separated from the 25 pin connector on the side of the machine. There are 10 wires in the ribbon cable but 2 look unused, the machine uses a serial connection to computer. Anyone have a wiring diagram or can take a picture of that spot where the ribbon cable is soldered to the 25 pin connector that would be great. Thanks
