scottboy1973 0 Posted May 29, 2012 The problem I am having is when I paste a file in SBD files in order to vectorize it, I can't see it when I open the import file. I can, however, see all other files I have saved in the past. I have opened the SBD files with explorer I can see it is their, just can't see it when I use Signblazer. I have tried saving as .bmp and . jpeg with no luck at all..I have done this successively in the past numerous times. This problem is a recent one.Is their a limit of capacity in the Import/Export files? I have also set up a new file in SBE files and put the new files in it just to try and resolve the issue with no luck. I am using XP. Thanks to all who help! Share this post Link to post Share on other sites
mb20music 760 Posted May 29, 2012 Have you tried Inkscape? It vectorizes much better than Signblazer does. Share this post Link to post Share on other sites
AbsoluteAirbrush 33 Posted May 29, 2012 +1 on inkscape Share this post Link to post Share on other sites
scottboy1973 0 Posted May 29, 2012 going to try inkscape as an alternative, thnx Share this post Link to post Share on other sites
mb20music 760 Posted May 29, 2012 You will like it much better Share this post Link to post Share on other sites
scottboy1973 0 Posted May 30, 2012 well i downloaded inkscape and vectorized the image successivly. I then saved it as and .eps file in the SBD files as before (and it can be seen there when exploring the file). But I still can't seen when I open the import file. Any ideas? Share this post Link to post Share on other sites
Dr12volt1338 116 Posted May 30, 2012 delete SB and reinstall Share this post Link to post Share on other sites
scottboy1973 0 Posted May 30, 2012 when i do that, what do I do to insure that the files that I have saved over the years will be safe. i definitly don't wan't to loose my library of vectors. And thank you for that advice! Share this post Link to post Share on other sites
mb20music 760 Posted May 30, 2012 Put all your vector files into a new folder, either on a hard drive or USB drive Share this post Link to post Share on other sites
