donnaredd
Roland PC 60 & FlexiSign Pro 6.5v3
I am using Roland PC-60 and FlexiSign Pro 6.5v3. After much trial and error I have finally gotten my laptop to recognize the parallel to USB connection. I have downloaded Roland driver and the software shows Roland. I import a purchased download of a rhinestone design (EPS) into Flexi and parse the postscript. I send it to the Production Manager thru Flexi and it processes from 0 to 100% using COM3 port......but the cutter never cuts!!!! I have checked mode in command prompt-it shows:
Status for device COM3:
Baud - 115200
Parity - None
Data Bits - 8
Stop Bits - 1
Timeout - OFF
XON/XOFF - OFF
CTS handshaking - OFF
DSR handshaking - OFF
DSR sensitivity - OFF
DTR circuit - ON
RTS circuit - OFF
Flexi has cut these designs on my brother's Roland CAMM 30" following this procedure - has to be setting errors - please help - I want to throw it out the window! I have a lot invested in downloads I can't cut or use.
Donna Redd
using com port with parallel cable will not work. change it to the correct port.
