han7681
can the signblazer run many cutters?
hi
i have few cutters with each pc to run.
can one signblazer in one pc run many cutters?
if yes, how to do ?
any advice welcome
thanks
Yep, you just will have to select the cutter and the output device for the cutter you want to cut with.
hi
thanks for answer ,
i manged to cut 2 cutters with one pc,
but whenever cutting a new, do i need to change output device setting?
for example.
open a 2 sign blazer, then one is usb 1 output setting in signblazer , the other is usb2 output setting in signblazer ,
after cutting finish, usb1 always change into usb2., so have to change back to usb 1 when cutting a new one,
how i can solve? how i can fix the usb out ?
thanks
Try installing it twice but the second time in a different directory. The settings should be stored in the installation directory allowing you to have two cutters.
