han7681 0 Posted April 8, 2012 hi i have few cutters with each pc to run. can one signblazer in one pc run many cutters? if yes, how to do ? any advice welcome thanks Share this post Link to post Share on other sites
mb20music 760 Posted April 9, 2012 Yep, you just will have to select the cutter and the output device for the cutter you want to cut with. Share this post Link to post Share on other sites
han7681 0 Posted April 15, 2012 hi thanks for answer , i manged to cut 2 cutters with one pc, but whenever cutting a new, do i need to change output device setting? for example. open a 2 sign blazer, then one is usb 1 output setting in signblazer , the other is usb2 output setting in signblazer , after cutting finish, usb1 always change into usb2., so have to change back to usb 1 when cutting a new one, how i can solve? how i can fix the usb out ? thanks Share this post Link to post Share on other sites
Jay2703 704 Posted April 15, 2012 Try installing it twice but the second time in a different directory. The settings should be stored in the installation directory allowing you to have two cutters. Share this post Link to post Share on other sites
