pbcmedia
signcut productivity pro wont open ai cs4 or eps files correctly HELP!!!
problem 1.. i do the work in illustrator, when i save the file with ai extension i get error msg when i go to open file "error, cannot open embedded pdf-files. save file in older AI or EPS format and try again. do not use the compression parameter in illustrator"
problem 2... when i open eps file just a blank box shows up in sign cut.....
im banging my head on the keyboard over here... someone help pls!!!!
I had the same problem. I just had to use the "Trace options" in Illustrator then it went into SignCut correctly.
