mountaindr3wz 0 Posted March 17, 2012 So I took the plunge and bought a MH-871mk2 cutter this week. I've been reading the set-up procedures online on the forums but my set-up still isn't functioning properly Now only if I could get some help with the fellow users on board here to chime in, then that would be perfect. my setup: Macbook Pro 10.6 snow leopard MH 871-MK2 Sign Cut Pro (I'm using the free 1year it came with) The Key Span Adapter (installed the CD it came with) Now the problem I'm having is when I run sign cut pro and I click cut, nothing seems to happen. I just want to cut the signcut Pro logo to make sure everything works out. I attached some pictures to make sure I'm on track with everything. Any help would be appreciated, thanks. Share this post Link to post Share on other sites
mb20music 760 Posted March 17, 2012 it probably is not a vector, that is why it will not cut do some text and try to cut that Share this post Link to post Share on other sites
mountaindr3wz 0 Posted March 17, 2012 thanks for the reply! I now tried to cut an .eps file that I pulled off the net to test it out and still nothing. Share this post Link to post Share on other sites
mountaindr3wz 0 Posted March 17, 2012 still nothing . But aren't the SC and MH series different? So I would have to use the Key span adapter for the MH series? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 17, 2012 still nothing . But aren't the SC and MH series different? So I would have to use the Key span adapter for the MH series? Sorry, I misread, you have a Refine not a Sc cutter...I was reading about an SC cutter earlier, sorry for the confusion.. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 17, 2012 have you read this post and or tried it? I am not a mac user, just trying to help you... http://forum.uscutte...ac-usb-writeup/ Share this post Link to post Share on other sites
mountaindr3wz 0 Posted March 18, 2012 I really appreciate the help Skeeter. I tried that and downloaded the driver, and still nothing. I used the keyspan adapter and got it to show up on signcut but it just doesnt start cutting. Weird stuff going on. Share this post Link to post Share on other sites
mountaindr3wz 0 Posted March 19, 2012 I figured it out, Thank you everyone! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 19, 2012 I figured it out, Thank you everyone! GREAT!!!!!!! Share this post Link to post Share on other sites
stetson5331 80 Posted March 19, 2012 You might post the solution so others that may have a similar problem will give some help for them that you requested help for yourself.. Share this post Link to post Share on other sites
mountaindr3wz 0 Posted March 21, 2012 Solution: instead of using the Refine or Uscutter in the cutter selection window, I used: Manufacturer--> roland Cutter--> PNC-1000 thanks Share this post Link to post Share on other sites
