knucklebucket 8 Posted March 16, 2012 okay so I bought this pro series 515 from the company I work for. the cost was 10 dollars. the cutter seems to be functional as in I can run a test cut from the control panel and move all the servo axis's. I called Bren got the registration re acitivated and it loaded up on my pc and shows ready but everything I send to it, it immediately fails to print. like there is no communication going on at all. It has the older parrallel cable so I bought a parrallel to usb cable and no resolve. going to try a serial cable this weekend but if this doesn't work hell I am out of ideas. figured I would ask the pro's that's been here a long time or short time with much experience if they might have any insight or ideas. thx ahead of time Share this post Link to post Share on other sites
Dr12volt1338 116 Posted March 16, 2012 What driver are you using for your cutting software? Share this post Link to post Share on other sites
knucklebucket 8 Posted March 17, 2012 well I have tried sign blazer, inkscape, tried to send a print job with notepad, I have a copy of photo illustrator in the mail. when I bought the cutter I went to bren.winline.com and downloaded there drivers for the cutter. Share this post Link to post Share on other sites
Dr12volt1338 116 Posted March 17, 2012 You will still have to find a driver that is built into signblazer so signblazers production manager can communicate with the cutter. Share this post Link to post Share on other sites
knucklebucket 8 Posted March 21, 2012 so signblazer doesn't specifically have a drive built in for the bren cutter. I have been told that one of the roland or graphtec will work but will have to sort them out 1 by 1. I'm just curious if i switch to a serial cable with a null modem if I can use photo Illustrator to cut. I have managed to get it to work. I can write text with micro soft word and send it the the bren and it cuts it beautifully. I have called bren and the software they use for their plotters is Bren cut engrave for 170.00. so even if I buy the software, that is still only 180 invested in a 4000 dollar vinyl cutter. i cant find the software anywhere else. Share this post Link to post Share on other sites
Dr12volt1338 116 Posted March 21, 2012 I would try all the drivers in SB first if you like that software... Otherwise for the $170 software designed to go with your machine sounds like a pretty good deal to me. Share this post Link to post Share on other sites
Jose Luis Tavarez 0 Posted March 18, 2019 Tengo un plotter bren 515 pro series y no tengo el sofwear para usarlo y cortar mis trabajos , por favor si alguien puede ayudarme Share this post Link to post Share on other sites
