s and t custom shirts 0 Posted March 14, 2012 i was cutting an image today i cut 3 images all the same the first 2 cut just fine the 3rd image it cut about half way the it stopped cutting and started to cut a line all the way down the side of the vinyl and this is not the first time it happened Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 14, 2012 Sounds like you are connected thru USB,, It has been stated many, many times here to go to keyspan adapter. Or a USB to serial connection. . Just do a search for keyspan adapter here on the forum. you will see how well it has helped others. Share this post Link to post Share on other sites
s and t custom shirts 0 Posted March 15, 2012 i did not keet a keyspan adator with my cutter but i did get a serial cord should i try switching to that Share this post Link to post Share on other sites
s and t custom shirts 0 Posted March 15, 2012 get im sorry Share this post Link to post Share on other sites
Rodger 527 Posted March 15, 2012 If you have serial on your computer , 4-sure . better than the adapter in my experience . BTW , you can edit your post Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 15, 2012 i did not keet a keyspan adator with my cutter but i did get a serial cord should i try switching to that yes, as Roger stated, if you have a serial connection on your computer, that is the best way to go.. Share this post Link to post Share on other sites
s and t custom shirts 0 Posted March 15, 2012 ty all i will try fisrt thing tomorrow and let you guys know how it goes this forum is awesomefor info and i did not even think about editing my post Share this post Link to post Share on other sites
s and t custom shirts 0 Posted March 15, 2012 it is not cutting the line so far but i am trying to cut a small image the samme i was working on yesterday and it is peeling away some of the letters yesterday i was using the 45degree blade today im using the 60 and it is still doing it any sugggestions Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 15, 2012 it is not cutting the line so far but i am trying to cut a small image the samme i was working on yesterday and it is peeling away some of the letters yesterday i was using the 45degree blade today im using the 60 and it is still doing it any sugggestions sound s like too much blade exposed... adjust the blade in, take the blade holder out of the cutter, cut firmly across a piece of scrap vinyl that you are cutting. Should only cut the vinyl, and no mark or barely a mark in wax paper backing. Adjust to get there. Then put holder back in vinyl cutter and use the force to get the same results. Share this post Link to post Share on other sites
