heritagedesigns 0 Posted March 10, 2012 Hi Guys! I'm new to cutting stencils. I see the adhesive backed stencil rolls and I want to try it out but I am not sure how you can have a "reusable" stencil and keep the letters (like "O's") and what not in place. So I guess my question is, what the the proceedure for using a "reusable" stencil? Do I have to do something different when I'm cutting? I know I need a 60 degree blade, but my main question is application and taking off so we can reuse. Thanks for ANY help! Share this post Link to post Share on other sites
Jay2703 704 Posted March 10, 2012 You would have to use a font that keeps the centers of letters connected. Look for stencil fonts. http://www.dafont.com/theme.php?cat=114 Jay Share this post Link to post Share on other sites
Ravenwind / One Off Grafx 187 Posted March 10, 2012 There are several ways you can do it. You can add tabs or cut 2 stencils 1 being positive the other negative. there are some good videos on YouTube about making stencils. Share this post Link to post Share on other sites
Heather 0 Posted April 27, 2012 this video was very helpful to me: it tells you how to "bridge the letters" for cutting stencils. my issue is cutting the actual stencils. I purchased 3 mil mylar and am using a 60 degree blade but the mylar keeps "shiftiing" during the cutting process causing it to get snagged - almost as if the pinch rollers aren't holding it down well enough. anyone have any advice? I have played around with different pressure settings & can't seem to get it to work consistantly. Share this post Link to post Share on other sites
Rodger 527 Posted April 27, 2012 I have seen metal stencils online that has 2 plates for any font etc . I am not sure what the best way to make those out of vinyl . They make stencil material with a removalabe backing so a cutter can cut it . I just use a vinyl stencil as a 1 time use . Share this post Link to post Share on other sites
Jay2703 704 Posted April 27, 2012 this video was very helpful to me: it tells you how to "bridge the letters" for cutting stencils. my issue is cutting the actual stencils. I purchased 3 mil mylar and am using a 60 degree blade but the mylar keeps "shiftiing" during the cutting process causing it to get snagged - almost as if the pinch rollers aren't holding it down well enough. anyone have any advice? I have played around with different pressure settings & can't seem to get it to work consistantly. I did that video a long time ago. Where did you find it? Share this post Link to post Share on other sites
