thegirlscreate 1 Posted February 22, 2012 I recently change my blade on my machine, ever since I did that the blade wiggles during cutting and it will basically just perforate the vinyl in some area's- I have to constantly adjust it. Any idea's why this would happen? Share this post Link to post Share on other sites
edge 67 Posted February 22, 2012 The new blade has a good edge and is the same dia and length? Disassemble the holder and check for small particles of vinyl that might interfer with the blade's movement. If all else fails....does the old blade perform the same if used again? Share this post Link to post Share on other sites
thegirlscreate 1 Posted April 17, 2012 I think I discarded the old blade, I have checked and readjusted it a million times it is the most bizarre thing! I have figured out a work around that seems to be okay as long as I keep an eye on the machine. Share this post Link to post Share on other sites
Rodger 527 Posted April 17, 2012 make sure you have tghe blade exposure right , there are countless posts about adjusting the blade , especially from Skeeter . If you can't find it , search Skeeter's content in her profile . Share this post Link to post Share on other sites
mb20music 760 Posted April 17, 2012 I have figured out a work around that seems to be okay as long as I keep an eye on the machine. What is your work around? Share this post Link to post Share on other sites
