wickedstangs 42 Posted February 18, 2012 Trying to vectorize this image so I can cut a decal out of it. Thank You Share this post Link to post Share on other sites
smokeybearfan 87 Posted February 18, 2012 Here is a quick EPS trace. It will need cleaned up, TSP-Evolution.eps 1 Share this post Link to post Share on other sites
wickedstangs 42 Posted February 18, 2012 Here is a quick EPS trace. It will need cleaned up, 100 times better than I can do:) thank you so much.. Ok, I think I cleaned it up a bit, how can I break it apart in Sign Blazer for different colors? Share this post Link to post Share on other sites
wickedstangs 42 Posted February 18, 2012 here is what I have so far and can't get the line blue.. tsp2.SBD Share this post Link to post Share on other sites
Signs Down Under 19 Posted February 19, 2012 Why bother taking all that time to vectorize and clean it up... It's only basic text !! Match the font and outline it in SB. Then punch through and delete the centre's so your just left with the outline. Copy the Purple curve and place it in position. Would take no more than 2 minutes to create it. Share this post Link to post Share on other sites
wickedstangs 42 Posted February 19, 2012 Why bother taking all that time to vectorize and clean it up... It's only basic text !! Match the font and outline it in SB. Then punch through and delete the centre's so your just left with the outline. Copy the Purple curve and place it in position. Would take no more than 2 minutes to create it. I tried that but, not working for me.. This is what comes out.. Couldn't match the font? TSP.SBD Share this post Link to post Share on other sites
Signs Down Under 19 Posted February 19, 2012 Here you go... Had a few spare minutes while having lunch. SB and EPS files. TPS.SBD TPS.eps 1 Share this post Link to post Share on other sites
wickedstangs 42 Posted February 19, 2012 Here you go... Had a few spare minutes while having lunch. SB and EPS files. That worked perfect.. Thank you very much... Share this post Link to post Share on other sites
Signs Down Under 19 Posted February 19, 2012 No Prob's Share this post Link to post Share on other sites
