PBR Allstar 0 Posted February 10, 2012 I have an image and after vectorizing it left me with two fairly broad lines instead of one solid line for the outline, think of it like a pair of railroad tracks. I want to delete the two inner paths so I just have one broad line. Curious if there is an easy way to do this instead of doing it one node at a time? thanks, sorry if this is a rudimentary question. -ford. Share this post Link to post Share on other sites
DLA1234 2 Posted February 10, 2012 Not sure if I totally understand what you mean, but you can select more than one node at a time by dragging a box around them and then deleting. I'm assuming you are using inkscape? You can also select more than one node by holding the shift key while selecting (or it's the ctrl key, can't remember). Hope this helps. Don Share this post Link to post Share on other sites
Jay2703 704 Posted February 10, 2012 Arrange + Split will break them apart to seperate elements. You can select and delete what you don't want them Arrange + combine to put together what's left. Share this post Link to post Share on other sites
PBR Allstar 0 Posted February 10, 2012 Thanks Jay, that seemed to work. not sure why I didn't think of that? the last week has just been a wealth of new knowledge and remembering things about graphics that I had totally forgotten for the last ten years. thanks again, ford. Share this post Link to post Share on other sites
