adcentre 0 Posted February 9, 2012 Hi all, I just purchased a new pcut ct630 and opened up signblazer to do a test cut. The word that I cut came out back to front as if mirrored and 90 degrees out from what showed on cutting window. I didnt use mirror command or rotate etc so figured it must be some kind of xy issue or other setup step, has anyone else had this problem or know how to rectify?? Any help would be much appreciated as I cant use my flexi 7.6 as cutter wont finish any designs (stops just before end of job) regards Lee. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 9, 2012 Hi all, I just purchased a new pcut ct630 and opened up signblazer to do a test cut. The word that I cut came out back to front as if mirrored and 90 degrees out from what showed on cutting window. I didnt use mirror command or rotate etc so figured it must be some kind of xy issue or other setup step, has anyone else had this problem or know how to rectify?? Any help would be much appreciated as I cant use my flexi 7.6 as cutter wont finish any designs (stops just before end of job) regards Lee. Did you read my reply to your Flexi problem on another thread you started.? Share this post Link to post Share on other sites
tammylynn49459 0 Posted August 14, 2019 My Sign blazer is cutting the same way, and when it completes my cutter is "waiting". I have uninstalled and re downloaded sign blazer with the same problem. Share this post Link to post Share on other sites
slice&dice 2,450 Posted August 14, 2019 tammy, if you are interested in help here, more info is needed. Let's first see a screenshot of the Cutter setup. Also, what does the file look like? Post it here, please. Share this post Link to post Share on other sites
