peps1 0 Posted February 1, 2012 Sorry if this is the wrong place, but Im unsure if its a hardware/software issue? My Cutter has no trouble with curves or circles of any size, but when I get into smaller cuts using right-angles I have a little trouble weeding without removing the cut letters. This is really a issue with L's I's 1's and !'s What settings sould I look at tweeking to get the better results? Also are there any good rules of thumb I should know for cutting small text as I have trouble with text under 2cm a character (cutter has 0.025 MM/Step resolution) (Im using flexi 8.5 on a USCutter SC Series Vinyl Cutter/LIYU SC631E). Share this post Link to post Share on other sites
cutme 5 Posted February 1, 2012 do you have your blade offset set to .25? bb Share this post Link to post Share on other sites
peps1 0 Posted March 13, 2012 Yes, offset set to .25 and overcut set to 0.30 on slowest speed setting? Share this post Link to post Share on other sites
