gomer 4 Posted February 6, 2012 i downloaded the ftdi driver and got the DOS window, installs and tells me press enter. start up SB and still not working. Share this post Link to post Share on other sites
Signs Down Under 19 Posted February 6, 2012 Have you checked that in device manager and SB that both are set the same (Try using com 4 in both) Also have you checked comm settings in SB. Baud Rate - 9600 Data Bits - 8 Parity - None Flow control - Hardware Also make sure the above is the same in device manager. You will need to right click the com port in device manager to check that. Sounds to me you haven't got everything synced together to work. 1 Share this post Link to post Share on other sites
gomer 4 Posted February 21, 2012 i havent gotten this fixed yet, i havent had time working 7 days a week. but i find that i had more then one FTDI driver installed, that may be part of my problems. Share this post Link to post Share on other sites
