gomer
SB cutter drivers
i downloaded the ftdi driver and got the DOS window, installs and tells me press enter. start up SB and still not working.
Have you checked that in device manager and SB that both are set the same (Try using com 4 in both)
Also have you checked comm settings in SB.
Baud Rate - 9600
Data Bits - 8
Parity - None
Flow control - Hardware
Also make sure the above is the same in device manager.
You will need to right click the com port in device manager to check that.
Sounds to me you haven't got everything synced together to work.
i havent gotten this fixed yet, i havent had time working 7 days a week. but i find that i had more then one FTDI driver installed, that may be part of my problems.
