jogavallarta 0 Posted January 29, 2012 pls help me. i been working for my new mh721. still i dont know whats the problem. the cutter did not cut the image correctly. this is my eps file. just only simple. 3 and sun.eps this is what the outcome in my mh721. 3 and sun.eps Share this post Link to post Share on other sites
MZ SKEETER 4,440 Posted January 29, 2012 Have you looked at the big Sun? Zoom it up... There is an extra object on it, that doesn't look like it should be there in your file http://support.uscut...iddle-of-my-cut Turn any weed lines off, your using up memory. Share this post Link to post Share on other sites
jogavallarta 0 Posted January 29, 2012 Have you looked at the big Sun? Zoom it up... There is an extra object on it, that doesn't look like it should be there in your file http://support.uscut...iddle-of-my-cut Turn the weed lines off, your using up memory. sir how to turn the weed lines off? do i need to turn it off in illustrator or in signcut? thanks Share this post Link to post Share on other sites
MZ SKEETER 4,440 Posted January 29, 2012 turn weedlines off in Signcut... Did you look at that .eps file? The Big sun doesn't look right... Share this post Link to post Share on other sites
jogavallarta 0 Posted January 29, 2012 help pls. how to turn the weed off. thanks Share this post Link to post Share on other sites
MZ SKEETER 4,440 Posted January 29, 2012 is your file supposed to have the extra object on the sun? Look at your file at the lower left side,on the sun. there is an extra object there. That doesn't look like it belongs there. Share this post Link to post Share on other sites
therese@whisqu.se 17 Posted February 17, 2012 Hello. Please save your files as AI-format, Compability 8,0. That normally helps. I can see that you use EPS-format. Also when you have your file in Signcut, open the preview and check that everything looks like it should. If it does then this is a driver problem and we at SignCut Sweden need to take a look at it. If it doesn't look okay it has to do with how the file was created or saved. Regards, Therese Löfström Share this post Link to post Share on other sites
