mazz
Cutter cuts back to origin during run
I am a novice with my machine, a USCutter sc40 with FlexiSTARTER and have run into my first problem.
Randomly during a cut it will return to the starting point then continue back to where it left off then continue on cutting. This wouldn't be a problem if it didn't cut the whole time it travels to the origin and back. It does it randomly at different points for the same pattern. Sometimes there is no problem at all. Why would it all of a sudden do this?
Thanks in advance,
Mike
reduce the nodes in your design, some times wen the file is big the cutter can not process all the bits on to the plotter memory
