tungtle
Refine 365 12" Desktop Cutting Problems, Missing Cuts or Mis-cutting
So I have a Refine 365 12" Desktop Plotter. Using a Mac with most updated sign cut pro software, using keyspan serial adapter. Cutspeed at 220 and Force at 10-20.
I've had success with a lot of work, however every now and then, I'll get a logo that doesn't want to cut properly. My most recent job, the plotter will start off perfectly, cutting about 60% through, and then it skips several letters on the bottom half of the logo, it'll then continue to cutting text on the top half, and then it'll cut the weeding border around like its finished, however it'll then scroll about 6-7 inches down and continue cutting the missing letters.
Tried using the pen to test it out, and same results. Any help?
Maybe a probelm with the file itself, and the way it was vectorized? File needs to be cleaned up perhaps, eleminating eroneous nodes.
Could just be some garbage in the cutter memory from the previous cuts as well. Never hurts to turn the cutter off and back on to clear the memory if it acts like this.
