palmettotrooper 1 Posted December 10, 2011 I have recently purchased an SC series cutter and installed all the software and drivers. Upon turning on the cutter, the motor goes the right and seems to get stuck. It sounds like it is wanting to cut but cant. Gets stuck to the right and makes a really loud buzzing noise. Any tips or suggestions to what it may be? Support is off for the day im driving my self crazy trying to figure this out!!!! Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted December 10, 2011 Check to make sure that the cutter head has not came off track or that there may be something in the way stopping the cutter head Share this post Link to post Share on other sites
palmettotrooper 1 Posted December 10, 2011 The cutter is in the track and nothing is blocking. It goes all the way to the right and never stops trying to continue moving to the right. It is really loud and the screen on the cutter says "uscutter" and doesnt change. I turned the cutter on and it did this. I cut it off, hooked it to the computer and turned it back on and it did a test print. Attempted to cut out my first decal and it went straight to the right and is stuck there. If I force it to the left, when i cut on the cutter, it goes directy to the right again and sticks..........ANY SUGGESTIONS???? Share this post Link to post Share on other sites
arty-rc 719 Posted December 10, 2011 On my MH-721, you turn it on and hit the ofline button. Then use the arrow to move the cutting head to the left, thus making a new starting point for the blade. It may be the same on your machine. Share this post Link to post Share on other sites
palmettotrooper 1 Posted December 10, 2011 none of the controls allow you to move the motor. The reset button keeps the motor quite while pressed but once released the motor screams again like its cutting. It's doing everything in its power to coninue going to the right. Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted December 10, 2011 Did you do a ticket on it ? Call usc support it could be something simple or even defective anyway they should be able to walk you through trouble shooting. Dan Share this post Link to post Share on other sites
palmettotrooper 1 Posted December 10, 2011 Yeah, I haven't spoken to uscutter yet. Non business hours Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted December 10, 2011 they are on Pacific time For Support Call: 425-902-1302 M-F 6 am-4 pm, Sat 10 am- 3 pm PST Share this post Link to post Share on other sites
palmettotrooper 1 Posted December 10, 2011 submitted a ticket and will reply back with there solution. Thanks for all the advice Share this post Link to post Share on other sites
palmettotrooper 1 Posted December 10, 2011 called support and they were closed. Called sales and talked with benjamin. He listend to my problem and told me exactly what to look for. There was a green switch on the back of the channel that wasn't making contact with the motor causing the motor to think it still had to travell to the right. Bent the arm a little and wam bam thank you mam. We are in business! 1 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted December 10, 2011 there ya go.....glad to hear it was an ez fix...good luck.... Share this post Link to post Share on other sites
Ernest 1 Posted February 2, 2020 Thank you Palmettotrooper ! called support and they were closed. Called sales and talked with benjamin. He listend to my problem and told me exactly what to look for. There was a green switch on the back of the channel that wasn't making contact with the motor causing the motor to think it still had to travell to the right. Bent the arm a little and wam bam thank you mam. We are in business! this post is excellent, my problem was solved thank you !!!!!!! 1 Share this post Link to post Share on other sites
