JoeCamaro 11 Posted February 5, 2008 I was looking trough SignCut x2 settings and I saw the blade offset was set to 0.025 and the box of the blades + this forum members suggest setting the offset to 0.25. I changed the setting and it starts cutting a doodle, many lines at the same time. I kept looking and the blade box says 0.25 MM, my software is set to cut in inches. SO, should I look the equivalent of 25mm in inches in order for it to work properly since my settings are in inches not in mm? Or should I write 0.25(mm) and it should work fine anyways? Im lost here. Joe PS This are my settings. Is there anything unusual? Share this post Link to post Share on other sites
Kimon 1 Posted February 6, 2008 I'm sorry if there is some confussion but in SignCut-X2 the blade offset is set to inches if inches is used in the program, we keep the same measurement unit everywhere to avoid confusion. Most manufacturers use mm on their boxes so the correct offset should be 0.012 although some users have increased their settings on refines up to .0185 Share this post Link to post Share on other sites
JoeCamaro 11 Posted February 6, 2008 Thank you Kimon!!! That is good to know! :thanks: I appreciate it. Share this post Link to post Share on other sites
NukleoN 34 Posted July 20, 2010 I'm sorry if there is some confussion but in SignCut-X2 the blade offset is set to inches if inches is used in the program, we keep the same measurement unit everywhere to avoid confusion. Most manufacturers use mm on their boxes so the correct offset should be 0.012 although some users have increased their settings on refines up to .0185 This was confusing me too. Entering .25 wasn't playing nicely with my LP24 from SignCut ProdPro, and I am using inches in SC as my default unit. I wasn't sure whether SignCut was showing the offset as mm (regardless of my setting) or inches since there's no indication of units in the offset field. So, what's the proper mm figure for the offset on a 45 degree blade? Is it .25 or .025? I keep seeing people post both numbers. Also, I am seeing that .25mm converts to 0.0098425197 inches. Where did this .012 figure come from? Share this post Link to post Share on other sites
CRD 9 Posted July 20, 2010 Look if your SC PRO main screen if it is in inches or mm sizes. If that is the case your offset is also mentioned in inches or mm. Easy or not. Set it in mm and start with 0.05 mm and increase by 0.05 mm. Paco Share this post Link to post Share on other sites
