gogetemgraphix 1 Posted February 5, 2008 i'll tell ya, if it isn't one thing it's another.... anyone have any trouble with it? it doesn't seem to stay put on the backing, i am having trouble with it .....while it's rolled it's fine but when i cut something it....buckles....is that the word? width wise across it and when i try to smooth it back out it either creases or won't lay back down. it will do it while it is cutting and the pain is when it cuts over those humps you don't get a clean cut. is there a trick to using this stuff? thanks lue anne Share this post Link to post Share on other sites
arhash 0 Posted February 5, 2008 I had that trouble with some thin foil. If you pre-cut the piece you are using off of the roll and then load it back into the machine then feed it back and forth the length of the cut it usually helps a lot. This relieves tension. --Arthur Share this post Link to post Share on other sites
gogetemgraphix 1 Posted February 6, 2008 :thanks:!!!!! lue anne Share this post Link to post Share on other sites
