island_tribe2002 0 Posted October 21, 2011 okay I am using Roland CutStudio for my plotter, I have about 5-6 designs that I want to cut on one sheet once it starts printing the first or sometimes the second one it makes a straight line and or it does not finish the design and then moves on to the next design and then it does not even finish the rest of the design. This is getting FRUSTRATING. ~~~~~~~Advice Please~~~~~~~~ Thanks Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 21, 2011 download Signblazer and use it. It is compatible with the MH series cutters. And best to put your cutter on a serial cable, and if on a stand, ground the stand to the cutter. Share this post Link to post Share on other sites
mark-s 1,126 Posted October 22, 2011 Possible open paths? mark-s Share this post Link to post Share on other sites
wn8z 0 Posted October 22, 2011 I second the serial cable suggestion. I've had the exact same problems when using usb on my lasercut - these problems were worse when using an extension cable in addition to the short usb cable. When I changed to a serial input on the laserpoint all of the unexplained "glitches" dissappeared... Share this post Link to post Share on other sites
island_tribe2002 0 Posted October 23, 2011 Thanks for the replies i will switch and let you know if the problem is fixed Share this post Link to post Share on other sites
