Jump to content
How To Do It in SignBlazer.
  • Please log in to reply
45 replies to this topic
#21 slice&dice
slice&dice
    Advanced Member
  • Members
  • PipPipPip
  • 4,081 posts
  • LocationMidAtlantic Region, USA
Posted 12 August 2012 - 06:19 AM
The years fly by, and here we are, left with the delightful legacy created by Jerry Bonham.
Since I began this journey into the realm of computer-cut lettering, I always have admired and appreciated his efforts to provide the cutting/sign-making community with an extremely useful application.
Although this thread has been left dormant, I just discovered a "How To Do It" item that would be nice to offer here --
Fonts sometimes need to be messed-around with, to create effects that aren't straight-line!
The easy way to perform this is type your word(s), select, and then go to the "ARRANGE" menu, choose "Convert to Curves"
Now, you can play around with the font in various ways (Double Click on each letter, and the entire node path is available).
In this example, I skewed the font, and then pulled a few of the corner nodes apart.
(After altering the node points, just return to "Select" and the results will be applied)
Have fun!
  • Attached File  draw.JPG   101.42K   4 downloads
#22 jennrsnyder
jennrsnyder
    Newbie
  • Members
  • 4 posts
Posted 21 June 2013 - 11:31 AM
How do I shade color in a design when in signblazer can someone please respond for instance its shaded dark as a svg file but when I import it into signblazer as an eps file it only has an out line. I wanted it shaded exactly like the picture.
Thanks,
Jen
#23 Jay2703
Jay2703
    Advanced Member
  • Members
  • PipPipPip
  • 6,792 posts
  • LocationEastern Washington
Posted 21 June 2013 - 12:00 PM
Can you post the .svg file?
24" VinylExpress Enduracut+, SignBlazer, Adobe CS3, InkScape
#24 Spunky.Fresh.Designs
    Advanced Member
  • Members
  • PipPipPip
  • 90 posts
  • LocationFort Lauderdale
Posted 20 August 2014 - 07:19 AM
I'm trying to open both .eps and .svg files in SB and nothing is happening.  HELP!?
#25 Mz SKEETER
Mz SKEETER
    Advanced Member
  • Members
  • PipPipPip
  • 12,130 posts
Posted 20 August 2014 - 07:24 AM
Signblazer has not been updated for years.Owner passed away several years ago.  Only accepts older .eps files like version 8.  and not svg at all.  You have to convert svg files in Inkscape.org to eps files..
Graphtec FC7000MK2-75 Flexistarter 8.5/8.6 Toshiba laptop Windows XP, Toshiba laptop Windows 7, Flexisigndesigner10
#26 Spunky.Fresh.Designs
    Advanced Member
  • Members
  • PipPipPip
  • 90 posts
Posted 20 August 2014 - 07:31 AM
so Ai6 won't work with signblazer?
#27 Mz SKEETER
Mz SKEETER
    Advanced Member
  • Members
  • PipPipPip
  • 12,130 posts
Posted 20 August 2014 - 07:50 AM
save files back to older version 8   I have CS2  and I can save back to older version 8  .ai and .eps
You can cut with SCALP. it came with your cutter, and has the plugin for Illustrator.   If you already have a great design software, why use Signblazer?  All you need is a great cutting software.  I use Flexistarter for my cutting software..  with a Graphtec cutter.  Can be had for under $130 on the big auction site.
Yes, you can cut with Signblazer,  but remember to save files back to older versions.  This is abandon ware, and will not be updated.
#28 Spunky.Fresh.Designs
    Advanced Member
  • Members
  • PipPipPip
  • 90 posts
Posted 20 August 2014 - 09:59 AM
Yeah....I think I'll uninstall.  thanks :)
#29 slice&dice
slice&dice
    Advanced Member
  • Members
  • PipPipPip
  • 4,081 posts
Posted 20 August 2014 - 02:18 PM
Just remember,  SCAL will limit you to a total working area of 200" and the text-handling capabilities are none too good.
(you cannot even type in two lines of text using the RETURN key)
I have used Flexi in the past and simply love it.
However, I remained with SignBlazer because of the 'cartoon' appearing interface.  Go figure !!!
#30 Spunky.Fresh.Designs
    Advanced Member
  • Members
  • PipPipPip
  • 90 posts
Posted 20 August 2014 - 03:21 PM
What if you do all of your text in illustrator? is that the way to go?
#31 vaportrail
vaportrail
    Member
  • Members
  • PipPip
  • 11 posts
Posted 21 January 2015 - 01:00 PM
There is some good information here, im bad with software myself, finally got my plotter to cut simple text,
Downloaded a few fonts as described in the first post here by the author.
Now it wont cut at all, like its hanging up af the plotter.
If i open the printer at printers and devices, it shows it there with no status.
You think i should abandon signblazer and try a different cutting software?
#32 Mz SKEETER
Mz SKEETER
    Advanced Member
  • Members
  • PipPipPip
  • 12,130 posts
Posted 21 January 2015 - 01:11 PM
Start here with the newbie manual..Download in first post
http://forum.uscutte...your-first-cut/
#33 Mz SKEETER
Mz SKEETER
    Advanced Member
  • Members
  • PipPipPip
  • 12,130 posts
Posted 21 January 2015 - 01:18 PM
Here is also SET UP GUIDE from USCUTTER.  pick your machine
http://start.uscutter.com/
#34 vaportrail
vaportrail
    Member
  • Members
  • PipPip
  • 11 posts
Posted 21 January 2015 - 04:39 PM
Thanks ill check those out
#35 deth502
deth502
    Advanced Member
  • Members
  • PipPipPip
  • 804 posts
  • LocationPA
Posted 21 January 2015 - 04:47 PM
make sure the settings in sb are set to the correct port for the cutter. i sometimes go to cut something and have nothing happen at the cutter, only to discover that sb has randomly assigned the cutter to be at some other port. i change it back and everything is fine.
#36 vaportrail
vaportrail
    Member
  • Members
  • PipPip
  • 11 posts
Posted 22 January 2015 - 09:53 AM
Thanks for the heads up I did see windows 7 requires a lower baud, What exactly does the baud do?
#37 darcshadow
darcshadow
    Advanced Member
  • Members
  • PipPipPip
  • 893 posts
  • LocationAzle, TX
Posted 22 January 2015 - 09:58 AM
baud, is baud rate and is a measurement of data transfer speeds.
I refuse to tip toe through life... only to arive safely at death.
Attack Life! It's gonna kill you anyway.
#38 vaportrail
vaportrail
    Member
  • Members
  • PipPip
  • 11 posts
Posted 22 January 2015 - 05:30 PM
i got both signblazers and neither are showing a mh plotter in the list at all am I missing something here?
#39 Mz SKEETER
Mz SKEETER
    Advanced Member
  • Members
  • PipPipPip
  • 12,130 posts
Posted 22 January 2015 - 05:39 PM
Try the REDSAIL ,  many have been using it.
And your cutter brand is REFINE MH
#40 vaportrail
vaportrail
    Member
  • Members
  • PipPip
  • 11 posts
Posted 22 January 2015 - 05:48 PM
the refine mh wasn't listed and thanks ill try redsail
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
