mb20music 760 Posted November 5, 2016 What are "knockout" images? can you post an example?? Share this post Link to post Share on other sites
slice&dice 2,450 Posted November 6, 2016 Sitting here wondering the same thing! (Maybe the WELD - PunchThrough feature is what's being referenced?) Share this post Link to post Share on other sites
Traci Cullen 0 Posted November 6, 2016 5 hours ago, mb20music said: What are "knockout" images? can you post an example?? here's an example of what a knockout image looks like Share this post Link to post Share on other sites
mb20music 760 Posted November 6, 2016 3 hours ago, slice&dice said: Sitting here wondering the same thing! LOL! Share this post Link to post Share on other sites
Traci Cullen 0 Posted November 6, 2016 Knockout is what they referred to it as when i was watching a youtube video. Share this post Link to post Share on other sites
Traci Cullen 0 Posted November 6, 2016 I dont want the body of the bear to show outside of the lettering, do y'all know how to fix that? Share this post Link to post Share on other sites
slice&dice 2,450 Posted November 7, 2016 Is this going to be cut vinyl? If so, just weed it away. It won't appear to be bears anymore, however. By the way, I'm has an apostrophe. Also, the space between the B and A looks too wide in comparison to the kern of the rest of the letters. Share this post Link to post Share on other sites
darcshadow 1,625 Posted November 7, 2016 There is not a direct way to do this in SB, but it can be done. Create the text and the image. Duplicate the text and combine the text and the image. You'll get what you have above, now draw a box around the new image, make sure the box is below the image and select both and do a punch through. Delete the image used to punch through and you should have the inverse of it inside your box. Now select this image and do a Split Objects then manually delete the portions of the bear that are outside of the letters. Once done, combine the remaining parts back to a single image and move it onto the top of your original text. This can be done much easier in Inkscape, by simply using the Intersection tool. As slide&dice pointed out though, if it's being done with cut vinyl you can simply weed out what you don't want. Share this post Link to post Share on other sites
Traci Cullen 0 Posted November 7, 2016 Thanks for the help guys. Lol i know the im is supposed to have the apostrophe, i just put this together as an example. Share this post Link to post Share on other sites
