Why Waite Graphics
Just need some help
I am new to all this and i have the uscutter mh721 and i cant seem to get signblazer to tell the cutter to cut can someone plz help call me or text me 9894003881 plz i have ?s and no one around here will help
Help the folks help you!
What OS are you running?
USB or serial connection?
What exact problems show up, or error messages when you try to cut with SB?
Did you read the "newbie manual"? here:
With more info, someone here might be able to get things going.
What Bear said , plus just about every type of problem has been covered . It may not be easy to find without reading thru alot of threads , but if you use the right search terms , your answers will be here . Even reading thru stuff that is not answering your problem .. it will get you up to speed & save you alot of the experience of trying yourself . A wealth of knowledge here , ESPECIALLY with SignBlazer . I have read the SignBlazer section starting with the oldest thread forward to the present date ( not every thread ;) ) several times & there has not been a time where I didn't learn or comprehend something new . The more you know & understand , the more you can learn . Also much easier to understand any explanation given to you .
