SSW 0 Posted October 7, 2011 I need a little help fading colors together... I'm trying to create the Oval in the picture I attached. I can't get the colors to fade directly into each other like that. Any suggestions?? thanks guys! Share this post Link to post Share on other sites
stetson5331 80 Posted October 7, 2011 I need a little help fading colors together... I'm trying to create the Oval in the picture I attached. I can't get the colors to fade directly into each other like that. Any suggestions?? thanks guys! What design program do you have? it's actually called a gradient,,,In PS you would use the 2 color gradient tool and adjust it to be similar.. I am sure your design program has a similar feature?? Hope it helps.. stetson5331 Share this post Link to post Share on other sites
rodh2 16 Posted October 7, 2011 SSW, I am not sure how to fade the colors in Inkscape, I do not use Inkscape. However, in Corel draw there is an option for a mesh fill. You can color certain spots and move the colors around to get the fade effect. Look through all the tool in Inkscape for a color blend or a mesh fill option. I know this does not answer your question; I know someone that uses Inkscape will be along and help. I did a quick oval in Corel Draw. I hope that it will help you with your project until you find a way in Inkscape. Rod fade oval.eps Share this post Link to post Share on other sites
SSW 0 Posted October 15, 2011 Awsome! Thanks guys I figured it out! Inkscape has a gradient tool you can use under the fill and stroke properties. Share this post Link to post Share on other sites
rodh2 16 Posted October 15, 2011 Awsome! Thanks guys I figured it out! Inkscape has a gradient tool you can use under the fill and stroke properties. :thumbsup: Share this post Link to post Share on other sites
