SSW
Color Fading
I need a little help fading colors together...
I'm trying to create the Oval in the picture I attached.
I can't get the colors to fade directly into each other like that.
Any suggestions??
thanks guys! :)
post-6070-0-48191400-1318004007_thumb.jp
Any suggestions??
thanks guys! :)
What design program do you have? it's actually called a gradient,,,In PS you would use the 2 color gradient tool and adjust it to be similar..
I am sure your design program has a similar feature??
Hope it helps..
stetson5331
SSW, I am not sure how to fade the colors in Inkscape, I do not use Inkscape. However, in Corel draw there is an option for a mesh fill. You can color certain spots and move the colors around to get the fade effect.
Look through all the tool in Inkscape for a color blend or a mesh fill option.
I know this does not answer your question; I know someone that uses Inkscape will be along and help.
I did a quick oval in Corel Draw. I hope that it will help you with your project until you find a way in Inkscape.
Rod
fade oval.eps
post-3064-0-37262700-1318014970_thumb.jp
Awsome! Thanks guys I figured it out!
Inkscape has a gradient tool you can use under the fill and stroke properties.
:thumbsup: :thumbsup:
