decal duck 0 Posted October 5, 2011 Has any one used Greatcut Software it came with my cutter a Expert 24 .The cutter works fine but sometimes it wont finish cutting my design not sure if it is the cutter or software.I reboot the cutter most of the time that works. Thanks for any input you guys have helped me a lot on this forum which is GREAT keep it up! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 5, 2011 if on USB. put it on a serial. A Keyspan adapter. Your probably dropping...just a thought. Or could be static, if you don't have your cutter grounded to the stand , if there is one. Share this post Link to post Share on other sites
roxanneupnorth 106 Posted October 5, 2011 I have 2 GCC cutters and use Great Cut on USB connection without issues.. Share this post Link to post Share on other sites
decal duck 0 Posted October 5, 2011 if on USB. put it on a serial. A Keyspan adapter. Your probably dropping...just a thought. Or could be static, if you don't have your cutter grounded to the stand , if there is one. Thank You very much it came with a cable I will do that tonight.I have a lot of jobs to do and not wasting any vinyl is always good. Again Thanks from Texas Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 5, 2011 Your welcome, I hope it helps. Or at least it might narrow things down for you. From Indiana Share this post Link to post Share on other sites
decal duck 0 Posted October 10, 2011 Your welcome, I hope it helps. Or at least it might narrow things down for you. From Indiana OK I got an adapter hooked it up after not cutting correctly at a show.No problems as of now. Thanks Skeeter for the help and all that posted! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 10, 2011 your welcome, glad it helped you. Share this post Link to post Share on other sites
