QualeT Graphics 3 Posted September 3, 2011 Hello Friends.... I am doing some large graphics and I was wondering if there was an easy way to put transfer tape on with out getting wrinkles.... Any videos? Thanks for your help! Share this post Link to post Share on other sites
roxanneupnorth 106 Posted September 3, 2011 Do you have a tape holder?.....If so pull out your tape and tack it to edge of decal......Then with your hand smooth it down back to tape holder.....And use tape that is the right width.....You should have lots of sizes on hand.....El Cheapo Tape Holder 1 Share this post Link to post Share on other sites
QualeT Graphics 3 Posted September 3, 2011 Well thank you so much....I will give it a try. Share this post Link to post Share on other sites
JoeDirt 5 Posted September 3, 2011 cut your tape to the length and make a U with it, and center over decal and lay it down while gently pulling on the ends. Then squeegee from the center out. Takes a little practices but you will get it, be doing 5-6ft lengths in no time. Remember you can overlap the tape if needed, but the smaller the overlap (1") is better. (tip: if your going to overlap with paper tape and do a wet install, tape the overlap with some good scotch tape so it wont separate during the wetting or wetness lol .) Share this post Link to post Share on other sites
QualeT Graphics 3 Posted September 4, 2011 Thanks Joe Dirt.... cut your tape to the length and make a U with it, and center over decal and lay it down while gently pulling on the ends. Then squeegee from the center out. Takes a little practices but you will get it, be doing 5-6ft lengths in no time. Remember you can overlap the tape if needed, but the smaller the overlap (1") is better. (tip: if your going to overlap with paper tape and do a wet install, tape the overlap with some good scotch tape so it wont separate during the wetting or wetness lol .) Share this post Link to post Share on other sites
