Allaris
DJ 1350 plotter help
Hello everyone!
I really need help setting up this machine. It's a DJ 1350 plotter (Dongjiang or Tonxiang, no luck with finding a driver).
The thing is, my brother used to work with it on this pc (Win XP SP3), but had to reinstall everything. Now it won't work, and nobody knows how they installed the plotter - and I'm here to fix the problem (sort of).
Any ideas how to get it done? It has an LPT and a COM port. I have a serial-serial cable, and an LPT-USB cable. Which should I use? Do I even need a driver for a serial-serial connection? My brother says the plotter didn't need a driver, Corel 10 and ArtCut just "seen" it instantly (but Corel does not now, and Artcut won't install). Is that possible?
Or is there anything like an "universal driver" which could work, or even the driver of a similar plotter which is compatible with it?
I've ran out of ideas, and the thing starts to get on my nerves. Tried Signblazer, but it has no cutter with this name / model.
Any little help is very much appreciated, thanks in advance!
