lonestarcountrymusic 3 Posted August 16, 2011 Every time i try to import an *.EPS file into CutStudio it claims the file is a bad format. Any help on how to fix this? Share this post Link to post Share on other sites
pitkin2020 1 Posted August 16, 2011 maybe post the .eps up for someone to check. It would be quite odd if all the files are bad I suspect its probably a problem with the software Share this post Link to post Share on other sites
kenimes 42 Posted August 16, 2011 Might need to re-save the .eps files into an older version 7 or 8 format that CutStudio supports. Share this post Link to post Share on other sites
lonestarcountrymusic 3 Posted August 17, 2011 this is the file. InkScape wont open it. WSM_New.eps Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 17, 2011 this is the file. InkScape wont open it. inkscape does not open .eps files.. that why you save the files as a svg file and .eps file so you can import the svg file back in for edits. Share this post Link to post Share on other sites
lonestarcountrymusic 3 Posted August 17, 2011 either way i need this to open in CutStudio Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 17, 2011 I just imported it WESTSIDE MUSTANGS Share this post Link to post Share on other sites
lonestarcountrymusic 3 Posted August 17, 2011 thats definitely not right Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 17, 2011 WSM_New.ai I put it on wireframe here is the .ai file done in CS2, see if you can import it. WSM_New.ai Share this post Link to post Share on other sites
lonestarcountrymusic 3 Posted August 17, 2011 wow it even claims the *.ai is a bad format Share this post Link to post Share on other sites
lonestarcountrymusic 3 Posted August 17, 2011 this is crazy. if i make something in InkScape i can cut it in CutStudio but it seems when ever people send me *.eps files it would work sometimes. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 17, 2011 this is your file Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 17, 2011 don't you have Illy or corel to work with your Cut studio? Share this post Link to post Share on other sites
lonestarcountrymusic 3 Posted August 17, 2011 nope didnt want to spend the money InkScape usually works for me Share this post Link to post Share on other sites
lonestarcountrymusic 3 Posted August 17, 2011 any idea on what to try next? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 17, 2011 can't you use Signblazer..? Alot of people here use it, and you can probably get more help with that. I use Flexistarter 8.6 for cutting, because it can import almost any type of file. Share this post Link to post Share on other sites
lonestarcountrymusic 3 Posted August 17, 2011 tried it. it shows its loading with the loading bar. then nothing shows up. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 17, 2011 try this one v8.eps WSM_New.eps8.eps Share this post Link to post Share on other sites
lonestarcountrymusic 3 Posted August 17, 2011 i appreciate it but i think that file is going to have lines cut where its not supposed to. its just a little off it seems maybe im wrong. i can show you a jpg of what its supposed to look like. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 17, 2011 were you able to import it? Nothing more that I can do with it... Share this post Link to post Share on other sites
lonestarcountrymusic 3 Posted August 17, 2011 were you able to import it? Nothing more that I can do with it... yeah it imported this is what its supposed to look like. Share this post Link to post Share on other sites
roxanneupnorth 106 Posted August 17, 2011 Looks like a poor quality trace that will take lots of editing to make usable.... Share this post Link to post Share on other sites
helpinghand 1 Posted August 17, 2011 This file was a mess....I do think I have it for you though. I use illustrator and cut studio and it should work fine for you now. Give it a shot and let me know how it works out. I had some time so played with it for you, I know how frustrating it can be sometimes. Heidi reuploaded as after Roxanne said still some extra lines I relooked at it and a few letters still had lines in them. Cleaned it up and tried cutting it, everything cut perfect for me. WSM_cleaned up.eps Share this post Link to post Share on other sites
roxanneupnorth 106 Posted August 18, 2011 Still looks like a lot of extra cut lines......I am not on my Illustrator computer so I can not do it right now......But if you enlarge it about 10x, rasterize it at 300 dpi and then re-trace it and remove the white all the extra cut lines will be gone... Share this post Link to post Share on other sites
