intelligentleman 0 Posted August 13, 2011 Hi, all. HELP ME, PLEASE! I beg of you!! XD I recently bought a 34 inch US Cutter MH871-MK2 with a 34 inch bed. My feed rollers are not working. It has nothing to do with the software, because they won't even move when I attempt to test cut. Everything else seems to be fully functional. Any ideas? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted August 13, 2011 can you move them by hand? check your belt... 1 Share this post Link to post Share on other sites
intelligentleman 0 Posted August 13, 2011 I was able to move them manually, and the belt is working fine. Share this post Link to post Share on other sites
vinylmotivations 143 Posted August 13, 2011 Based on your response here and in your other matching double post- It is a motor problem, that or a mainboard issue not telling the motor to move. Call USCutter tech support monday or submit a ticket. They will help get you squared away. Share this post Link to post Share on other sites
intelligentleman 0 Posted August 13, 2011 Based on your response here and in your other matching double post- It is a motor problem, that or a mainboard issue not telling the motor to move. Call USCutter tech support monday or submit a ticket. They will help get you squared away. thanks, will do. Share this post Link to post Share on other sites
