ralais 0 Posted August 8, 2011 I am not sure what happened to my cutter / software today but somehow, between cuts, my cutter settings must have changed. Everything I try to cut is cutting SUPER SMALL. On the screen it looks like it is the right size, but when I hit cut, it cuts tiny. Could someone please tell me what the cutting settings should be for a MH721 cutter? Share this post Link to post Share on other sites
mb20music 760 Posted August 8, 2011 well when you select the object to cut does it give you the size in the bottom in the object size box? Share this post Link to post Share on other sites
ralais 0 Posted August 8, 2011 The size at the bottom is actually larger than what I have it sest as AND it has a LOT ot extra material shown around the edges. Share this post Link to post Share on other sites
ralais 0 Posted August 8, 2011 I have been on hold for the Tech Support for 32 minutes now... I really need some help. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 8, 2011 did you try this? Info in support http://support.uscutter.com/index.php?/Knowledgebase/Article/View/23/5/my-cut-size-does-not-match-the-indicated-size-in-signblazer Share this post Link to post Share on other sites
ralais 0 Posted August 8, 2011 Yes... tried that one. No change. I also opened up SB on another PC I have to check the settings and they are the same. So now I'm really stumped... with a lot of work to get done. Share this post Link to post Share on other sites
ralais 0 Posted August 8, 2011 I went ahead and uninstalled SB and then reinstalled it... that worked. Still have no idea what was wrong because the settings are still the same. Share this post Link to post Share on other sites
Rodger 527 Posted August 8, 2011 Hey , this is the best download of SB I have seen . It is the UK version & has the patch download below it . Only thing i don't like is it doesn't have the same library clip art . edit ; 4-got to add the link ....http://www.mystat.com/ Share this post Link to post Share on other sites
