yaak 0 Posted August 8, 2011 Hi. I am brand spankin new to all this. We have FlexiStarter P-Cut Edition and i was wondering if it's possible to get the contour cut to cut inside letters like "o" "e" etc, so if i want to cut a transfer for a shirt there isn't little bits of white inbetween these letters? I have no trouble getting the contour cut set up but can't see anywhere to set inside contours. Thx. Share this post Link to post Share on other sites
vinylmotivations 143 Posted August 8, 2011 Yes- assuming you have 8.1 or 8.6 when you have your Design Central tool box open, when you select the contour option, in that small window there should be a check box that says [ ] With Holes. You check that and your good to go. Share this post Link to post Share on other sites
yaak 0 Posted August 9, 2011 Ah,that's great news. Thanks very much for your help Vinylcreations. Share this post Link to post Share on other sites
vinylmotivations 143 Posted August 9, 2011 Let me know if you can't figure it out or have issues... I am no pro at using Flexi by any means but I can do quite a bit with it. Search a bit around here and you will find an hour long tutorial video on USING Flexi that is VERY VERY good. I can post a screenshot if what I said to do you can't find. Thanks! ~Matt Share this post Link to post Share on other sites
