Flex8.6 Starter
#1
Posted 06 August 2011 - 04:44 PM
#2
Posted 07 August 2011 - 02:11 AM
With 8.6 starter can you acheive contour cutting? I have followed all of the outlined steps - but the outline cut line is not being printed nor is the machine reading the marks that flex told me to use for my machine?
Using Flexi , you use the contour feature not the outline feature.At least thats how my Flexi works..It will print reg marks for you to line up your cutter with..
More info is needed..What cutter, screen shots of your print screen, file your using..the typicall stuff to help diagnose your issue..Hope it helps..
#3
Posted 07 August 2011 - 05:35 AM
I
This is my first time attempting to use the contour cut, I "you tubed" and followed the direction. I wrote my name expanded it - used contour cut and the outlined showed, I adjusted it and hit the green check mark , when back into the contour tab and inserted the marks "for my printer" to the illustration.
Now when I printed the drawing it did not print the outline cut lines that appeared on the screen, but it still showed up on the production screen "the outline cut line" now when I attempted to cut the media, it showed mark detected but never cut! stating no cut line detected?
Spoke to a friend who ownes a sign business and he informed me that flex8.6 does not make contour cuts that I would have to upgrade to version 10 or higher - that is the reason for my question.
#4
Posted 07 August 2011 - 07:03 AM
http://cgi.ebay.com/...=item3f0c9306c1
#5
Posted 22 August 2011 - 12:48 PM
Dispute filed on both ebay & paypal - interested in seeing what happens next!
#6
Posted 22 August 2011 - 01:56 PM
There is Sign Go lite and Sign Go Pro, they also have a 30 day trial version.
http://www.ebay.com/...=item3f0d272a9a
Here is the Signgo site
http://www.signgo.co...cts/signgo.html
where is the ad of what you purchased??
show a screen shot of your program...the one you stated is wrong...
The Flexi-Sign store on Ebay sells Sign Go and ALSO Flexistarter 8.6 and 10. I have purchased my Flexistarter there with no problems..
If you compare Sign Go to Flexistarter, Sign Go has MORE features and effects than the Flexistarter 8.6 or 10. Flexistarter will not vectorize images, but Sign Go will. Or have effects for text. Or write text on paths. But Sign Go does. I have Flexistarter from 7.6, 8.5, and 8.6,vs2 They are basically cutting programs. That is it. Nothing More. Not much in design features at all. You can do some text, but not alot more, like in Sign Go..
So, if I'm reading your post above correctly, you filed a dispute with EBAY and Paypal because they sent you BETTER software than the Flexistarter 8.6 or 10? Interesting
#7
Posted 16 December 2011 - 12:36 AM
#8
Posted 16 December 2011 - 06:00 AM
FlexiSign Pro for only 30$
where is FlexisignPro for $30?
#9
Posted 14 March 2012 - 12:21 AM
e-mail me. ehmkyut30@yahoo.comwhere is FlexisignPro for $30?
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
