l!zerd 0 Posted August 1, 2011 when i click cutter settings in signcutpro, the mh871 isnt displayed under output device/port. it only displays /dev/cu.Bluetooh-PDA-Sync, Write to File, and TCP/IP. in another thread, it says to set my manufacturer to Roland DG, cutter to Roland PNC-1000 and so on and so on. everything else matches except for the output device. i installed the drivers from the uscutter site and it still isnt reading the cutter. Any suggestions? thank you. Share this post Link to post Share on other sites
rustyflakes 0 Posted August 3, 2011 I am having the same problem. i already used it on windows and it worked, so it has nothing to do with the cutter hardware. Share this post Link to post Share on other sites
diverr 0 Posted November 25, 2011 Hi, did you find de solution? I´ve the same problem. Thanks! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted November 25, 2011 here is a great tutorial for the Mac, And If you didn't purchase, a Keyspan adapter, You will need one for Mac. http://start.uscutter.com/mh-series/mac-osx Share this post Link to post Share on other sites
