cneil79 0 Report post Posted November 3, 2006 I was able to use artcut about a wek ago, b ut when I try to open the program now I get an error message saying to insert the cd-r and press ok. When I put the program CD in he drive and press ok, it then kicks me out the the desktop and, nothing happens. I tried to reinstall the program but it did not work. Any Help will be greatly appreciated. Thanks, Chris Share this post Link to post Share on other sites
gah7887 0 Report post Posted November 3, 2006 Try Start-Setting-Control Panel-Add/Remove Programs. Remove the software and reinstall ArtCut.. Restart the computer before running it.. Good luck Garry Share this post Link to post Share on other sites
MarcelC 3 Report post Posted November 3, 2006 When it is asking for the CD-R you should put in the white disk which is just to verify and finish the installation. After you remove the white disk nothing will happen but the Artcut program should start normally from the programs menu. Once the program is verified and running you do not need to insert either disk again unless you reinstall. Share this post Link to post Share on other sites
cneil79 0 Report post Posted November 4, 2006 Thanks Marcel that worked. Chris Share this post Link to post Share on other sites
MarcelC 3 Report post Posted November 6, 2006 Excellent, glad to hear that. Thanks for the followup Share this post Link to post Share on other sites
tzservice 0 Report post Posted April 3, 2007 I am having the same problem was working find I have uninstalled and reinstalled the software when it asks for the cd-r I put in the white cd and get the artcut 2000+ page for a second then it goes away nothing else will work from there Chris Share this post Link to post Share on other sites
kenimes 41 Report post Posted April 3, 2007 Maybe run a scan on your computer to see if there are any issues. Viruses cause this type of problem from what I've seen. :spider: Share this post Link to post Share on other sites
tzservice 0 Report post Posted April 3, 2007 Compute checks clean no spyware viruses Share this post Link to post Share on other sites
kenimes 41 Report post Posted April 3, 2007 See if you can get SignCut to work. It is the program we now bundle with all of our cutters. It is a nicer program, mainly because you can do inches, cm, or mm. Artcut only allows for mm. A free trial is available at www.sc-x2.com Share this post Link to post Share on other sites
aamotox 0 Report post Posted April 4, 2007 I am having the same problem with artcut. I've reinstalled it, put the graphic disc in and it does nothing. Can I trade this in for signcut? Share this post Link to post Share on other sites
kenimes 41 Report post Posted April 4, 2007 We cant take a trade-in for SignCut, but you can try the free trial version from SignCuts web site. If you decide you like it, we offer a discount for customers that had ArtCut. Share this post Link to post Share on other sites
UpNorthPromo 3 Report post Posted April 5, 2007 I am also having the exact same problem. I've reinstalled artcut, scaned for viruses, inserted the white disk and nothing seems to work. I have cut hundreds of yards of vinyl through artcut and all of a sudden today it is asking for the disk and nothing works to get it back up and running. I have a job that needs to be cut by tommrow and I'm getting a little worried. I really can't see buying another expensive program to do my cutting when despite the metric conversions artcut works just fine for me. Must be because I gotten so used to it I appreciate any other help you may have Share this post Link to post Share on other sites
aamotox 0 Report post Posted April 5, 2007 I feel the same way. I've gotten use to the piece of junk and have lots of designs already done that I need to cut. If I cant get artcut to work then I wont be able to export the files to any other program. I'm screwed! What operating system are you using? I have windows 2000. Share this post Link to post Share on other sites
aamotox 0 Report post Posted April 5, 2007 Does anyone have any answers as to why this program would work fine for three months and now all of a sudden stop working? I have people waiting on vinyl, so if anyone has any suggestions please let me know. Thanks. Share this post Link to post Share on other sites
TaterNuts 3 Report post Posted April 5, 2007 Well, Im not too sure on 2000, but on XP there is a system restore, where you can turn back the clock and have basically the same configuration when the program was working. First, I would check to see if the program is running on the background... Check task manager under processes to see if it is running in there... If it is running, kill it, and then try to re-start. If its not running, there should be some kind of logical reason... It sounds like to me that something went corrupt withthe install, or the uninstallation. Sounds like maybe some bad registry keys. I cant really tell you how to fix that besides re-installing widows... Could you try installing the software on another computer? I would start there. Share this post Link to post Share on other sites
Guest fivestar Report post Posted April 5, 2007 Either took a windows update or some new piece of software you installed would be my guess. I would do like Tater said and do a system restore back to a date that you knew it worked and see if it works again. Share this post Link to post Share on other sites
UpNorthPromo 3 Report post Posted April 5, 2007 Hmmm.... I went back a week and then 2 months and it still won't work. I got the job I needed done in the signpro trial but would like to get back to artcut. I much prefer the way it vectorizes raster files compared to signcut. Share this post Link to post Share on other sites
kenimes 41 Report post Posted April 5, 2007 I have emailed ArtCut regarding this issue, it seems to be very common recently. Their initial answer was to "insert the graphics disk" when asked for the CD-R I sent a response explaining that this is exactly what our customers are doing. Hopefully they get back to me with a solid solution soon. Marcus has suggested using the free trial download of SignCut available at www.sc-x2.com SignCut is simply a cutting program, but you should be able to save your graphics files as .eps or .ai and open them in SignCut to cut. I will keep everyone posted on ArtCuts response. :throw: Share this post Link to post Share on other sites
UpNorthPromo 3 Report post Posted April 6, 2007 I had this problem with the desktop computer I use now so I went back to my old lap top I used artcut on months ago and tried to open it on there and it has the same problem too. It work fine when I retired the computer and now nothing. Wierd. They were installed off the same CD at differnt times on differnt computers and all of a sudden they both stop working at the same time! Share this post Link to post Share on other sites
kenimes 41 Report post Posted April 6, 2007 Dont know if they are ignoring me, but I sent yet another email requesting an answer to ArtCut. Share this post Link to post Share on other sites
thredz 1 Report post Posted April 6, 2007 Yes Ken,they're ignoring you!(hehehe) Actually I think it's part of a great conspiracy.They are upset because their software used to be bundled with the cutters and now they are bundled with signcut.So,they sent a seeker virus to find and disable all of the artcut running on uscutters. Share this post Link to post Share on other sites
UpNorthPromo 3 Report post Posted April 6, 2007 I think I am going to give up on the artcut and get signcut. I read that there was a discount for artcut users. Does anyone know how to get it. Thanks! Share this post Link to post Share on other sites
kenimes 41 Report post Posted April 9, 2007 Well billy, I hope that is not the case. If they offered better support for their product we may have stuck with them. The solution for now is to use SignCut instead of ArtCut. It will take some getting used to, but it is a more reliable program. Share this post Link to post Share on other sites
thredz 1 Report post Posted April 9, 2007 I agree on that 100%! Artcut was on my computer for about two days and that was enough of a waste of my time. Signcut does take a little time,but it's a much better program than artcut. Share this post Link to post Share on other sites
