ttik 0 Posted May 25, 2011 Hi guys, I've attached Book1.pdf here and I'm not sure how to confirm the manual feed is out or not. As you can see in the pdf, I drew a few marks so that I can positioned them on my machine. Initially, I adjusted it to 2mm on the right. When I roll the paper out till it reaches 1700mm, the paper seems to shifted to right hand side about 0.4mm. Then returning back to 0mm where I was started, now shifted to right hand side about 0.1mm compare to 2mm(initial where i started). I am not sure I am doing the correct way to confirm the paper is skewed which will cause alignment out cutting. Which I am facing like attached Book2.pdf Kindly advise. Thanks Book1.pdf Book2.pdf Share this post Link to post Share on other sites
