youdude 1 Posted January 26, 2008 hey guys I finally got me a heat press 16x24 HIX ($100 by the way) got me some thermoflex plus but I don't have my teflon paper yet....it should be here tomorrow MAN am I impatient I need to do a shirt now WHAT can I use temporarily in place of the teflon paper to test one shirt??? HELP ME PLEASE....i know there has to be something Share this post Link to post Share on other sites
Guest fivestar Posted January 26, 2008 Nothing or if you must use the backing paper from a piece of vinyl. The mylar backing will protect the vinyl though, so you don't have to use anything. Just after you press it, wipe it down with a towel pressing firmly then pull the mylar backing off. That will help with not having to repress after the backing is removed. I press mine with mylar backing on, peel the backing off, then use teflon sheet and repress for 8-10 seconds, just to be sure everything is stuck, but the second press isn't necessary. Share this post Link to post Share on other sites
youdude 1 Posted January 26, 2008 i am using the Refine.....do you recommend any blade settings (force and speed) Share this post Link to post Share on other sites
Guest fivestar Posted January 26, 2008 Really depends on the graphic you're cutting for the speed but force I use about 30-40 grams more then I do for sign vinyl. One other tip......CUT IT IN MIRROR OR FLIPPED. BTW, you stole that press at the price.... :well done: PS. you can cut alot better detail with heat press vinyl then you can with sign vinyl, the vinyl won't peel us on very fine detail work like it does with sign vinyl. Share this post Link to post Share on other sites
youdude 1 Posted January 26, 2008 thanks FIVE for your help....and yes i did steal it from a friend of my sister.....only thing i don't like is it's the kind I had to hook up to my air compressor Share this post Link to post Share on other sites
stickygrafix 2 Posted January 26, 2008 we were told you could use wax paper (the kind you would use for baking cookies) lol Share this post Link to post Share on other sites
ShadowHawk 0 Posted January 26, 2008 I wouldn't recommend wax paper.. the wax will melt and get into the garment material. I generally use a heat-transfer sheet (that we use for making screen-printed transfers). G'Luck Rex S. Share this post Link to post Share on other sites
