jacek 0 Posted January 24, 2008 Hi guys I am trying to get some technical information about the "Laser Point Alignment for Contour Cutting!" and compare this with other existing cutters with same option. Obvious advantage of this cutter is its lower cost comparing to others. Please share if you know something about technical capabilities. Share this post Link to post Share on other sites
kenimes 42 Posted January 24, 2008 The laser is NOT an optical eye that "reads" registration marks, yet is used to align with two reg. marks on the pre-printed material, and once that is done, allows you to contour cut. You will use the included software, SignBlazer, to do you printing and cutting. The LaserPoint will work as a vinyl cutter with several other programs, but you will not be able to use the laser feature with other programs. Technical specs on the unit itself can be found at www.uscutterdirect.com Share this post Link to post Share on other sites
