craig 0 Posted April 22, 2011 Hi i have a problem with my cutter,it is not completely cutting letters like o and letters look rounded and not straight just installed new blade and it is all set up correct please help its killing me the font is just aerial and is 7.5mm high Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 22, 2011 Hi i have a problem with my cutter,it is not completely cutting letters like o and letters look rounded and not straight just installed new blade and it is all set up correct please help its killing me the font is just aerial and is 7.5mm high your not giving enough info, so how are your test cuts? are they sharp? Have you adjusted your blade offset so that it is cutting good? Tried slowing your cutter down? less blade? a drop of oil in the blade holder? blade spinning freely? No vinyl in the blade holder? Carriage head wheels firmly in the track? Share this post Link to post Share on other sites
craig 0 Posted April 22, 2011 your not giving enough info, so how are your test cuts? are they sharp? Have you adjusted your blade offset so that it is cutting good? Tried slowing your cutter down? less blade? a drop of oil in the blade holder? blade spinning freely? No vinyl in the blade holder? its not completing the full letter not closing the font so i go to weed and it not cut i have it at its lowest speed the manual says the cutting is not closed and too use the offsetting function in the software but i cant find how too do that? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 22, 2011 its not completing the full letter not closing the font so i go to weed and it not cut i have it at its lowest speed the manual says the cutting is not closed and too use the offsetting function in the software but i cant find how too do that? yes, it is probably the offset, but your not even stating what cutting software you are using.. Signblazer? Signcut? Flexi? what? Share this post Link to post Share on other sites
craig 0 Posted April 22, 2011 yes, it is probably the offset, but your not even stating what cutting software you are using.. Signblazer? Signcut? Flexi? what? sorry mate flexi 8.5 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 22, 2011 sorry flexi 8.5 ok in Flexi 8.5 enter something on your main layout. just a letter will work. > click File> cut. Go to the upper left corner where it says PROPERTIES, and click it. You get default job properties page. At the top click on the picture that looks like a blade go half way down and set your blade offset, it is in inches. Click apply ok. Share this post Link to post Share on other sites
craig 0 Posted April 22, 2011 How do i get into change the offset function flexi 8.5 please anybody?? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 22, 2011 How do i get into change the offset function flexi 8.5 please anybody?? look at the post above. I explained it to you... Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 22, 2011 you can keep adjusting it to get sharp corners. Just do some test cuts using your vinyl cutter on some scrap vinyl. Share this post Link to post Share on other sites
craig 0 Posted April 22, 2011 ok in Flexi 8.5 enter something on your main layout. just a letter will work. > click File> cut. Go to the upper left corner where it says PROPERTIES, and click it. You get default job properties page. At the top click on the picture that looks like a blade go half way down and set your blade offset, it is in inches. Click apply ok. it says knife offset is at 0.020 in what should it be i must say you r the master Share this post Link to post Share on other sites
craig 0 Posted April 22, 2011 you can keep adjusting it to get sharp corners. Just do some test cuts using your vinyl cutter on some scrap vinyl. it says the resolution is at 1016.000 steps/in what is that Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 22, 2011 it says knife offset is at 0.020 in what should it be i must say you r the master All I use is Flexi, you can adjust the .02 go one way and see if it gets worse, then go the other way. make sure your blade is barely showing,out of the blade holder. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 22, 2011 it says the resolution is at 1016.000 steps/in what is that you don't need to change this Share this post Link to post Share on other sites
craig 0 Posted April 22, 2011 look at the post above. I explained it to you... Thank you very much u r da best i have been a signwriter for 20 years and you never stop learning my offset needs too be set at .028 have agood easter cheers craig Share this post Link to post Share on other sites
craig 0 Posted April 22, 2011 One more query oh master? in my cut/plot i have too cut in reverse to get it cut not in reverse? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 22, 2011 One more query oh master? in my cut/plot i have too cut in reverse to get it cut not in reverse? LOL Sorry I don't understand, what you mean. Share this post Link to post Share on other sites
craig 0 Posted April 22, 2011 LOL Sorry I don't understand, what you mean. i have yet another problem? how do i change the compensation value? And when i have my cut/plot page up and it shows u what u are cutting mine has too be selected in reverse for it to cut normal Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 22, 2011 i have yet another problem? how do i change the compensation value? And when i have my cut/plot page up and it shows u what u are cutting mine has too be selected in reverse for it to cut normal I don't know what you are calling the compensation value. PLease explain Are you sure you are using the correct driver for your machine when you did your set up in Flexi? Share this post Link to post Share on other sites
craig 0 Posted April 22, 2011 LOL Sorry I don't understand, what you mean. the compensation function sorry the right angle is not cut correctly, in the manual it says if the right angle is not cut correctly please use angle sharp compensation function then it says too select the high precision output i have had this plotter from new 4 years ago and never had a problem untill now SORRY Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 22, 2011 the compensation function sorry the right angle is not cut correctly, in the manual it says if the right angle is not cut correctly please use angle sharp compensation function then it says too select the high precision output i have had this plotter from new 4 years ago and never had a problem untill now SORRY Are you referring to FlexiSign Pro 8.5? I do not have it. I only have Flexistarter8.5, So I don't have all the functions of FlexiPro. On the main layout screen, at the top of the screen. Is there a HELP? If so click there. Cause I can't help you with that. Share this post Link to post Share on other sites
craig 0 Posted April 22, 2011 Are you referring to FlexiSign Pro 8.5? I do not have it. I only have Flexistarter8.5, So I don't have all the functions of FlexiPro. On the main layout screen, at the top of the screen. Is there a HELP? If so click there. Cause I can't help you with that. thank you for all your help, i will try to solve this one cheers. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 22, 2011 thank you for all your help, i will try to solve this one cheers. cheers to you. where are you from? I hear your accent.... LOL ... Indiana USA here Share this post Link to post Share on other sites
craig 0 Posted April 22, 2011 cheers to you. where are you from? I hear your accent.... LOL ... Indiana USA here Gold Coast Australia nice and bloody warn today 2pm good friday just cracked a coldie Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 22, 2011 Gold Coast Australia nice and bloody warn today 2pm good friday just cracked a coldie I would love to come there... by the way, I'm not a master. I'm a woman LOL nice talking with you Craig.... Carolyn Share this post Link to post Share on other sites
