uniquesigns 0 Posted April 17, 2011 Anyone else have serious crashing issues when using illustrator cs5 and the signcut plugin? Share this post Link to post Share on other sites
AshComputers 197 Posted April 17, 2011 What OS are you using? Windows or Mac? Share this post Link to post Share on other sites
AshComputers 197 Posted April 17, 2011 os 10.6.6 Yikes, I hate Mac lol Get in touch with Kimon on this issue over at signcut. He comes on here as well. Just make sure if you are running usb to use a keyspan on that mac Share this post Link to post Share on other sites
uniquesigns 0 Posted April 17, 2011 I couldnt get the keyspan to work with the new scpro, it worked with scx2, but nothing now... Share this post Link to post Share on other sites
AshComputers 197 Posted April 17, 2011 I couldnt get the keyspan to work with the new scpro, it worked with scx2, but nothing now... Make sure all your software is updated. Also make sure the keyspan is still ok. If all else fails, contact Kimon Share this post Link to post Share on other sites
seveninphilly 0 Posted May 19, 2011 Had the same problem with Illustrator CS5 crashing with the SignCutpro plugin. Removed the plugin had to convert the file to eps and open with SignCut, I don't think SignCut is up to date with CS5 on mac yet. Share this post Link to post Share on other sites
Gear Head 1 Posted September 21, 2012 Figured it out. Once the plugin is downloaded. You need to go into your plugins folder for Ai, then the Extensions folder, then place the plugin there. Hope this helps someone down the road. Share this post Link to post Share on other sites
LuisN 0 Posted December 3, 2012 Where can i download the plugin for illustrator mac? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted December 3, 2012 they are found on Signcut site for plugins. http://www.signcutpro.com/downloads/plug-ins/plug-ins-1-00 Share this post Link to post Share on other sites
LuisN 0 Posted December 3, 2012 Im slow today but i noticed im using sure cuts a lot pro which they dont have it out i guess =\ Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted December 3, 2012 Im slow today but i noticed im using sure cuts a lot pro which they dont have it out i guess =\ You posted this under a thread where people were using SIGNCUT software. So, I could only assume you were using Signcut also. You should have made your own NEW thread with your problem, under the SURE CUTS A LOT software, section. (which is a totally different software) and different plugins. Share this post Link to post Share on other sites
LuisN 0 Posted December 3, 2012 Yeah i know, as mentioned im a bit tired worked late last night and didnt notice the names. thanks thou! Share this post Link to post Share on other sites
