nappycrew 0 Posted March 27, 2011 I actually had 2 issues. One is that I cant see the driver in illustrator to cut. I only see it in the File, Print and select roland. I s there suppose to be a separate command, for example when I send to cut in graphtec it has a separate menu (Cut plot). Does anyone know how to load the Roland cut driver to Illustrator. Second, Everytime I set my sheet it always give me a message " Sheet Unloaded", I already followed the direction making sure dress right dress and hit the markings. Any suggestions? appreciate it. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 27, 2011 I actually had 2 issues. One is that I cant see the driver in illustrator to cut. I only see it in the File, Print and select roland. I s there suppose to be a separate command, for example when I send to cut in graphtec it has a separate menu (Cut plot). Does anyone know how to load the Roland cut driver to Illustrator. Second, Everytime I set my sheet it always give me a message " Sheet Unloaded", I already followed the direction making sure dress right dress and hit the markings. Any suggestions? appreciate it. Illustrator is NOT cutting software, only design software, You need a cutting software. You could download the FREE Signblazer design and cutting software here on the forum for your Roland. I don't don't how to run a Roland, but I have a Graphtec, maybe someone else can help. I would try roll. If there is such an option. Share this post Link to post Share on other sites
steve worcester 0 Posted May 17, 2011 I actually had 2 issues. One is that I cant see the driver in illustrator to cut. I only see it in the File, Print and select roland. I s there suppose to be a separate command, for example when I send to cut in graphtec it has a separate menu (Cut plot). Does anyone know how to load the Roland cut driver to Illustrator. Second, Everytime I set my sheet it always give me a message " Sheet Unloaded", I already followed the direction making sure dress right dress and hit the markings. Any suggestions? appreciate it. With Roland it is Cut Studio software and there is an Illustrator plug in that has a little window to send it to Cut Studio. Share this post Link to post Share on other sites
Robert H. Bigart 64 Posted November 19, 2011 Check this out. Bob Bigart Cut from Corel-1-1.doc Share this post Link to post Share on other sites
