D4kustomz 3 Posted March 5, 2007 Ok for some reason my pc will not let me open Eps files do i need to download something to help open them its comes up to me as a word document Im sure Im doing something wrong Thanx all Jd of D4Kustomz Share this post Link to post Share on other sites
TaterNuts 3 Posted March 5, 2007 Are you trying to open up EPS files with signcut? Here are the steps to make is so when you double click on an eps file, it will open with sign cut Goto Control Panel (Start>Control panel) double click on folder options icon (If you do not see this icon, on the left hand side, click on "switch to classic view") Click on the file types tab In the registered file type box, scroll down to the eps extension and click on it ON the bottom of this window, you will see "Details for EPS extension" It says Opens with XXXXX (probably notepad) CLick on the change button, Select signcut by clicking on it Sign cut SHOULD be in there under recomended programs, if not, look under other programs. Make sure the box is checked that states "Always use the selected program to open this kind of file" Click "OK", this will close out the window, the other window that is open, you may have to hit apply, if it is shadowed out, just click close. Now, try double clicking on your eps file... Should work Share this post Link to post Share on other sites
Guest fivestar Posted March 5, 2007 Or "right click" the .eps file and then open with then choose default program and point it to your signcut. Share this post Link to post Share on other sites
TaterNuts 3 Posted March 5, 2007 Yeah, that way works too, but you will have to do that each time... either way will work. Share this post Link to post Share on other sites
D4kustomz 3 Posted March 5, 2007 Heh dont use sign cut cant seem to learn that as good as winpc or signgo sorry Share this post Link to post Share on other sites
TaterNuts 3 Posted March 5, 2007 I dont use sign cut either, im a pretty much die hard winpcsign user. Share this post Link to post Share on other sites
